John Robinson
Gone but not forgotten
Today it was 98 degrees out and I drove my car about 6 miles and then parked it for 3 hours. When I went to start it it ran very poorly and then it would quit. H ad a service engine soon light and so I went through several turn off engine restart cycles and it would not clear. Got the trusty paper clip out and read the codes. I had Code 15 Engine coolant sensor circuit. The FSM pointed toward a bad ground in circuit 410 or 808. Code 21 TPS high voltage Ground circuit 808 is the one for the TPS. Code 23 Intake air temp sensor circuit Low temp indicated. The FSM says if the air intake is warm the sensor will read low temp to the ECM. I suspect the fresh air tube was very hot from heat trapped under the hood.
Now hear is my question on the TPS I checked the voltage on it and it has .63 volts with a closed throttle and only 4.1 volts WOT. Per my FSM it should be .54 volts closed throttle and 5 volts WOT. Would this be a good indicator that the TPS is bad?
