Pseudomind
When returning from Cruisefest 6, just south of Atlanta, I had to perform a fairly quick stop for a fire truck which was up ahead and suddenly stopped on the inside lane, the truck did not have any lights/siren on. There was no road debris or any accidents.
Anyway after I got back under way my dash had the Traction Control and ABS warning lights on. All the DIC would display was "service traction control." I could get no other indications. I pulled off at the next exit at a fueling place, as I somehow seemed to remember something about shutting down and the errors resetting. I do not know if this is true or not, but in this case it seemed to work the errors went away and the DIC went back to normal display functions. Before shutting it off I did press the Traction button a couple of times in the hopes of maybe cycling through the settings. I seem to remember the default after shut down for the traction control is to be re-enabled.
Anyone out her have some further input on what might have happened? I drove on into Jacksonville and the lights never came back. They are still out now, which is good as far as I am concerned.
I would just like to know what might have caused it in the first place.
C4C5specialist, if you are not to busy and have any ideas I would welcome hearing them. I think something must have happened which caused a couple of bogus error codes to be thrown during the quick stopping.
