The rivits have been removed but the rotors will not pull off. They do rotate but will not slide offAny advice on removing the rear rotors? The car has been sitting for 7 years. How dificult is it to rebuild the trailing arm/hub assemblies?
that is great advice it worked for me just put back brakes back together todayspray it real good with PB Blaster or other penstrating oil around the hub and wack it good it will come off.
Also makes it imposable to adjust the Emergency Brake!!This is important on a car with fixed calipers like the C3s in order to preserve the runout measurement within specifications.
...They do rotate but will not slide off...
