froggy47
apologize, don't know the right name for this bit. It has 2 18mm bolts on each end, one end attached to the tail end of the zf6 speed the other end attached to the diff housing.
I was feeling a little movement (up down) slight in the shift lever on a high rev shift like the tran was moving up/down maybe 1/8 inch so I thought I'd go look around.
I can turn one of the 18 mm bolts with an open end wrench pretty easy, I figure from the size it ought to be torqued 150 ft lbs or so.
Gotta drop the exhaust (of course) to get to it.
Questions are:
1) What's the torque spec
2) Should I add some medium loctite (remember this one gets raced a bit)
3)Is there a nut on the other side?
How to hold the top side while you torque the bottom, do you need two people? Any tricks of the trade?
Many thanks
1996 LT4 Coupe
1996 LT4 Coupe
Black/gray 50k miles
Questions are:
Many thanks
1996 LT4 Coupe
1996 LT4 Coupe
