D95
Does anyone know how many degrees cooler the transmission will be by adding a trans cooler to a stock LT1 with a 180 stat. Temps before adding cooler and after.Would you also use the stock radiator cooler in conjunction with the added on cooler.95 and 96 does have a trans temp gauge
