Just popping this back up, in case anyone has new ideas.
So far, it seems that the only streetable option in a currently-manufactured longitudinal transaxle that has the differential up front is Quaife, and their prices are, shall we say, a bit on the high side...
Out of curiousity, does anyone know what the dimensions of the current-production Corvette transaxle are? Specifically, the distance from the front (engine surface) of the bellhousing to the axle centerline?
I'm trying to design a mid-engined car, in the same general size class as the Shelby Cobras and similar small roadsters.
I've read, in GM's marine engine catalog, that the LSx engine measures 28.5" from the front of the pulley to the rear of the block. So, if I were to mount the transaxle directly to the engine (no torque tube), I could end up with a mid-engine setup. But I have a sneaking suspicion that it will push the engine and, as a result, the firewall, too far forward into the cockpit...
Still, maybe I've mis-estimated the dimensions of the Corvette transaxle. If so, it would simplify things to use a standard GM part...
Joe
