Transgo Shift Kit
  • Thread starter Thread starter Alwyn678
A
Alwyn678
If you are considering a Trans-go shift kit DO it...I just installed one and it is Amazing ...Before the 1-2 shift was sluggish at best...After installing the kit set to aggresive mode it will almost turn sideways when I am a full throttle....Shifts extemely hard and fast. Also it is still very streetable and is still smooth at less extreme speeds. My car has been modified and it really adds to it
Any chance you can give us a blow by blow of what it took to install it, cost, and any problems you had along the way?
I think this link may explain it better than I ever could...The whole thing can be done in two hours or less easily. While you are there you may want to also go ahead and drop in a tranny cooler "while you are at it"
http://www.camarobay.com/Transgo.htm
