Transmission slip 1979
levittown
New member
Levittown
1979 silver & red
My 1979 corvette with automatic transmission slips out of drive after about
45 minutes of driving. I can down shift then it will go back into drive for
a little while, then slips back out ? I'm a back yard mechanic ,but in the back half of the back yard!
Its going to need a rebuild....The fluid gets hot thins out and the worn clutch apply seals cant hold pressure causing slippage.
First, pull the dipstick and smell it. See what color the fluid is. If the fluid is dark or has a nasty smell, figure on a rebuild. IF it's nice and red and not stinky, Drop the pan and see how much trash is in there. It could be anything from plain old worn out seals to a partially plugged filter. On the good side, a backyard mechanic- even one that's way out in the backyard, can rebuild a TH400 with a little time and effort.
