R
R.T.
Has anyone had a problem with the Tremec 5 speed TKO getting stuck in 4th gear. ad
I have talked to Keisler and Tremec and it "so they say" hasn't happened before although they just got one shipped back with the same prob, and I know of another Camaro with the same isue. On acceleration in 4th it sticks. The middle dog in front the shifter gets stuck forward so you have to take the inspection cover off and move it back,,no easy task. $4600 tranny and I have to take it out and send it back,,no easy task either.
All the extras will do it.$4322.00 to be exact,,,,,
I have the order on a PDF but I don't know how to upload it to post. It's a
TKO 600 starts at $3195 then the bell housing flywhell clutch etc etc etc.
Just don't try putting one in a 63. Doesn't work with solid mounts and too many mods needed to make it work.
I am considering putting it in my 64. Would I have the same issues as with your 63?
I did a TKO install in Y2K back before the days of Kiesler and the offset shifter. I have well over 40,000 miles with no problems but I have a B&M ripper and it is not in the stock location; I like it that way the Ripper shifts just takes a flick of the wrist.
BTW my install was less then $3000 flywheel to U-joint and the basic TKO trans is still $1975
http://www.fortesparts.com/index.cfm
Actually it is in my 76 I will be putting it in the 68 with a fresh 383 next year.Boss. Whas it a 63 or 64? If it was your 68 we're talking a whole different setup up as far as clearances and body mounts.
I had to modify the trans mount and the shifter location but thats about it, pretty much a straight forward trans swap. the only differance is the shifter location.
anything over a 3:36 with the TKO is a waste I have a set of 3:08 R&P on the way to replace the 3:70's in the 68. I will find out the 68 has aluminum body mounts and sits about an inch to 1 1/2 inches lower then the 76 does I may have to swap to later rubber body mounts to get the body up a little but that will smooth out the ride. The C5 has spoiled me, I hear every little creak and groan when driving the 68.
http://www.classicchevy5speed.com/Corvette-1963-67-Kit-Select.aspx
I will say, bar none, next to my engine, heavily modified 327+, this is with out a doubt, the best mod you will ever make on your C1, C2. It makes your car a totally different car:confused
