DonB
With all the recent talk about batteries, storage and maintainers; I changed my battery Saturday with a new Interstate AGM. The main issue I dreaded was resetting all the multitude of settings in the C6. Then I had a brainstorm.
Enlisting the help of my trusty Crapsman battery charger, I connected my Red (+positive) battery charger clip to the output post (Red 12 volt) on the alternator and the Black charger clip to the mounting bolt of the alternator for the (-) ground. Set the charger to LOW or 2amp. Then plugged in the charger and turned it on.
Now you can remove the battery cables from the battery without loosing the 12v. for the system memory. Be careful NOT to touch the positive battery cable to ground because it's live. Once the battery cables are back on tight, FIRST, TURN OFF the battery charger and then remove the leads from the alternator. You don't want any current arcs at the alternator. At the battery the ground cable comes off first and goes back on last.
You see there are diodes in the alternator that basically turn the alternating current the alternator produces into DC to charge the battery and operate everything. These same diodes prevent the power from the battery charger from back-feeding into the alternator and causing any damage.
Works like a Charm! VIOLA! (And, Yes,..I did figure this out myself.)
