trim tag 1975 vette
  • Thread starter Thread starter Buffaloman57
B
Buffaloman57
I can't fined it. Can any one help me locate it. It should be pop riveted some where correct?
The trim tag on my 75 is on the drivers side inside the door near the hinge on the body. If you open the door and look near the top hinge you should see it.
same location through 82 i believe. it is the same on my 78. just below the window frame inside the door jam on the driver's side.
