only conclusion for the type of damage would be that "air is breaching the filter", any restriction to the air filter would not cause any of these symptons.
It seems the majority of us got this one correct. It is #3.
#1 would not be caused by unfiltered air.A restricted filter would cause lack of engine's ability to increase in rpm's. (can't breathe)
#2 the MAF only reads what ever gets past the filter
#4 incorrect air supply will not cause overheating
This also can illustrate how inferior air filtration can cause engine wear. It won't manifest itself until the miles get up over 100-125k maybe more on borderline air filtering systems. Of course no air filter would hasten the wear.
