Trouble Codes off '96
Tallahassee, FL
none right now :(
Is there a way on the late C4's to pull the codes without a reader? I know you can on the C5. I would rather not pay for a scanner:)
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
You need a special OBDII scanner which you should be able to find at your local autoparts store.
Cruise
Barrie, Ontario, Canada
1994 coupe
I don't know if this will work on your '96, but on my '94, I had the key turned off, took a paperclip and connected the #4 and # 12 pins, then turned the key on and wrote down my error codes.
I posted this issue on July 25th, titled Error codes on OBD2 for a '94.
Here is one of the responses that I recieved.
It might work for you
The procedure Cruise used will work on a 95. The 16 pin connector is numbered left to right, 1 thru 8. The bottom is, left to right 9 thru 16. Ground pins 4 & 12 & then turn ignition "on" but not to start.
After turning the ignition on the CCM will display any DTC"S & the module to which they apply in an automatic display sequence. The CCM is module 1.
The PCM/ECM is module 4. The ABS/TCS EBTCM is module 9. The DERM is module A
During display each DTC is displayed for 3 secs, The end of the DTC list for each module is indicated by "___" being displayed in the speedo..
A C-12 indicates no stored DTC"S for the CCM.
When all DTC"S have been displayed the trip monitor will display 1.0 & the speedometer will be blank.
If you need more please e-mail.
Rabbit
Corvette Ownership
1995 ZO7 drk red metallic
