L
lheindrich
I am trying to trouble shoot my broken horn and I need some help here this is what I have done so far with the help of old posts on the site. First I bought a horn because the original was pulled out and I connected it yesterday. So I am missing some parts or they are old and broken up at the actual horn. I need a horn contact brush because it is missing and I need a nw horn button contact assembly because it is broken. My main question is how do I make sure the circuit is going to work before I get all the parts? I tested the horn by putting 12v to it and it works fine then I went to the relay and put 12v on the green lead and the horn works fine at the relay I put a voltmeter on the red lead and I get 12v the black lead from the relay leaves and goes to the horn button through the steering column. What do I do to make sure the circuit works from the horn with the relay reconnected how do I prompt the relay to close from the horn contact? Could someone explain how the circuit actualy works? Thanks for any help.
