sxyvet
- Joined
- Aug 3, 2005
- Messages
- 248
- Location
- Dandenong,victoria-Australia
- Corvette
- 1991 ZO7 coupe, 6 speed,red on red w/most options!
hi there guys!
hope all is well with you all!
at the moment i have a set of full length tuned 1/3/4" diameter ,4 into1 pacemaker headers with high flow magna flow cat with magnaflow straight thru rear mufflers along with 2/1/2" mandrel bent pipes!
but the front y-pipe from the headers back goes into a single cat 3" then out back too dual pipes!
but i was wandering will i gain more power and a better deeper sound buy running a true twin single system all the way thru each side instead of twin into single back out to twin again?
i would also add a x-pipe section half way between system as well!
so i would be adding back two high flow cats one each side with a 2/1/2" mandrel bend pipe for each side would be better?
any advice would be really great!
thanks
glen
sxyvet
Australia
thanks
glen
sxyvet
Australia
