Tune up maintenance?
  • Thread starter Thread starter 1996man
1
1996man
Hey guys. This probably seems like a no brainer but i just want everyones input in case i missed something. I dont have a dyno pull to back up my theory but i beleive my LT4 is running a lot weaker than it should be. One big reason I suspect this is I raced JTB who dynos 284rwhp and the only way i was staying the smallest bit ahead of him was that i have a lot higher redline and was able to shift a lot later. We raced several times and each time was the same. I was only ahead by a nose. Granted I will give it to him that he is a good driver but that instance along with the fact i can only manage to seem to get 13.5@107 as a best at the drag strip, I think I am down a bit on power. My question is this. What thigns are often case the source of this problem? I know i have a lot of miles (142K) and some of the things i plan on doing in the near future are plugs, plug wires, fuel filter and changing the fluid to redline in teh tranny and diff. Am i missing anything? what else should I check? Do you think by replacing these things i should be back up to a stock dyno of about 300rwhp?
__________________
Yes, a car that has old plugs and wires will definitely make less power than it should. Whether you can feel that power is another issue.
I think the "typical" LT4's dyno in the 300rwhp range or so. Of course, they were underrated so if the figure was higher, I wouldn't be surprised.
And don't forget to change the oil and use a high quality oil and oil filter. Old oil will kill your mileage.
__________________
Doesn't the 107 mph show that you are getting about 300 rwhp now?
Looks like your traction and/or driving technique could use some work.
Or you could race me, I'm really slow.
