S
sscam69
Before I started to bolt back up my new manifold (see other post) I needed to check if the timing was off on my car. I had checked the timing with a timing light and I could not see the mark on the balancer as the light flashed. So I assumed that the balancer had spun.
Well I had my brother put his thumb on #1 spark hole and told him to let me know when the air was pushing his thumb out. Sure enough he told me "when" and I could see that the rotor on the HEI was coming around and point to #1 as Vig! had suggested. I could also see the mark on the balancer coming around towards the driver side, I was turning the engine from the passenger side.
So I told him to stick a straw in there and tell me when the piston would stop moving as it reached the top. The let me know "when" and the rotor was pointing to #1 and the mark was lined up to the 0 on the tab:confused
Maybe the timing gun was messed up or something?
So we swap out the manifold and do all the other stuff and after it was all said and done I told him to crank the engine and sure enough fired up. I ran inside to get the timing gun, hooked it up and sure enough I could see the mark but it was hiding under the water pump as the light flashed. I turned the distr. and brought it into view.:confused
ad :eek :dance
So what went wrong? Well it is really hard to read the tab because the mechanic painted it and its really hard to read the degrees and which degrees are TDC and BDC. As it turns out I though the marks for BDC were TDC so the timing was always way off and I could never see the mark.
So in the end the balancer was fine
and I was reading the tab wrong
