Twilight Sentinel Lighting
  • Thread starter Thread starter 01TriBlack
01TriBlack
Lots of light subjects - good info, thanks. I just received my window sticker from the museum on the car I recently purchased and the car has Twilight Sentinel Lighting (included in some option group). Can someone tell me exactly what this is?
Thanks much. :)
Mary
When Twilight Sentinel is activated, the head lights will automatically turn on when it senses a low level of light and turn off again when the light level is high enough, and turn off automatically after you shutdown. Press the Options button on the right side of the dash and Twilight Sentinel should pop up as one of the first options that you see. It's probably set to "OFF" since you haven't noticed this issue. Besides activating them, there is a 'delay' time setting that determines the amount of time they stay on after you shutdown.
One thing you may notice with the sentinel activated is that the head lights will come on in the garage after you start but not if the parking brake is set. When you release the parking brake, the lights will pop up and on. After I back out into the sun, they turn off a few houses down the street.
Thanks, Tuna! Much appreciated. So for all intents and purposes, once the TS option is "on," I really don't have to mess with turning the lights on or off, correct? We've got a Denali that has this feature...yet it's not called Twilight Sentinel Lighting (I don't think). I'm thinking it's the same concept, then.
Something rather odd. The car's battery was dead again, so my son was out jumping it. I was watching and noticed that the light "doors" were closed, but I could see the headlights "on" through the cracks. What could have been going on there? Anything to do with this TS option?
Also, one other thing, if you don't mind. Are the parking lights (that's what I call them - I don't know the correct term for them) to be on all the time? I thought they were. These don't seem to be.
As you can tell, I'm familiarizing myself with the car in spurts as I'm not able to drive it yet (due to weather). I appreciate your help. :w
TS should work similar to the Denali except you'll notice the head light doors open and close. ;)
I don't have a clue on the issue with the battery being dead. Normally, when the head light doors are down, the lights are off. This is something you'll need to look at.
The parking lights/turn signals are the 'daytime running lights' also. When the car is started, they should be on and bright if the lights are off. With the lights on, they dim. When using a turn signal, they should flash between bright and dim. If they are not on when the motor is running, there may be another problem for you to look into.
Hope this helps.
Yep! You helped a lot. :cool Thanks! I sure hope to heck this car doesn't have issues. Since I'll have it into the dealership for some warranty issues (as soon as it's formally out of storage), I'll ask them to go over the DIC options with me. I'm sure they'll do it....for a price.
Surely there is a local Corvette club in your area with members that would be more than happy to get you aquainted with your Vette and do it for free.
Twilight Sentinel Lighting option missing from DIC
Hi, I figured I would post this here in case someone had an answer for this. My Twilight Sentinel option is not showing in my DIC options. I read somewhere that this can be just a bad fuse. Is this correct? My past car had the option displayed so this wasn't an issue.
Sounds like someone needs to read their Owners Manual. :happyanim:
They could ship the car but not the manual?;LOL
The internet is a good thing sometimes:
http://www.c6registry.com/Technical/manuals/2004corvette.pdf
PS: Did you pull the DIC codes on the car before you bought it? That info is not in the OM. That feature makes the C5 a good purchase with all the gremlins the car can have. If you don't know about that feature let us know.
I am going to post this info in case you need some more reading material. Also here is a video that might help the written guidance.
Corvette C5 Trouble Code Procedure - YouTube
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
