coptertom
Can't believe it happened.....the dreaded "Pull hood release; Driver side pops open & passenger side stuck"!
I've search the Action Center Forums; along with every web sight I could find......No Luck.
The best description I could find to help open the hood was Mid America's Tech help. Still no luck. I removed the rubber plugs located on the firewall by the windshield wipers. Was even able to some how stick a 6 -7 inch flat head screw driver in the hole, but was not able to find the hood lock latch.
Tried going up through the engine compartment from the bottom with a long pipe to unlatch the passenger side latch, you guessed it; No luck.
Since the driver side latch opened, I even tried pulling up the driver side of the hood and pulling on the cross over cable; Again no such luck.....the cable obviously broke off at the passenger side latch!
Here is where I need the HELP: Would anyone possibly have an actual picture of the passenger side hood latch mechanism for a 72? Maybe this will help me to visualize what lever I need to pry to open the latch, using a long screw driver through the hole.
All of the information found say's that the latch that needs to be pushed is located directly behind the hole in the wiper area......If it is I certainly can't find it. ad
