R
RhinoB1
Ihave an 81 and before I had the rearend rebuilt, it kept trashing the right side outer ujoints, (halfshaft came off outer flange AT SPEED 3 different times before I had it rebuilt.) So, when it was rebuilt, replaced both inner flanges and right side outer flange, half shafts brand new . That worked great for about Half a mile till camshaft broke destroying engine. Anyway, got new engine and drove about 1500 miles on it and rear end was now squatting and took to get aligned. While doing alignment, mechanic noticed inner left side u joint was bad. Had them replace it and worked good for about 30 miles. I replaced again this weekend and lasted about 5 miles this time, (luckily no repeat of half shaft space shuttle launch). I don't really think that ujoint type or mounting strap type is the problem, it would trash all of them if it was. Any Ideas on what could be the problem? Thanks, Ryan
