Zixxer
I originally had the rotors and new pads installed all the way around on my 96 LT1 about 500 miles ago. At the time the tech noted a small tear in the boot on one of the front calipers and mentioned I might need to address that in the future. Additionally, the entire brake system was flushed. I put new tires and rims, paint the calipers (careful not to get any where it doesn't belong) and watched myself on the break-in process. The front left rim appeared to have a lot more brake dust build up so I suspect the right caliper was sticking...based upon the previously mentioned torn seal. I went ahead and bought two new calipers (remans) and had them installed. The tech mentioned I might need to replace the front pads again since there was probably some glazing, or we could sand them. Well it's been about 300 miles and there's still a lot more brake dust on the left side. I also replaced the front brake lines when I got the calipers. I haven't taken it back to the shop because I wanted to see if anyone could offer some advice first. Thanks Rick
