1KULC7
I have not posted in a while because of so many things going on... First I have just accepted a job working for the Federal Government in a high level position for DHS...US Customs and Border Protection...so I have been very busy with this...but for the part you really want to hear about, the Road to Top Flight, with my 63 Coupe...
As many remember in the past I posted almost three years of updates and photos of a frame off restoration on my 63 Coupe. Many came over to visit when I was at Carlisle and Ocean City, and I received many compliments about the car, and I thank each of you for taking the time to see the results of 3 years. But I still was not happy with a few items and felt in order to earn Top Flight for NCRS things would have to be improved.
As of March 15 the car went back into the shop and we are doing a lot more work. So here we go. First all the chrome and exterior trim was removed again...I found two spots on the paint that I did not like and we are going to shoot the car again. So the spots have been resanded and primed. In doing this, I am going to take the opportunity to dullen the door jambs and the hood jabs, as they are to glossy...this helps with NCRS points. I have found an original spare tire tube, howevers somebody clear coated it, removed the clear coat. Overall the tub is in good physical shape, but it seems to be bleached out because of age. To refinish it back to it original gray luster with those fiber hears I am going to use GRAY Shoe polish and reshine it...beleive it or not it works with no yellowing effect.
Replacing the side mirror to a dated one, and then tearing out the seats and redoing the carpet, replacing it with correct carpet, and doing the "toolbox" areas under the seats, repainting it.
Also, I found the outside window trim on the drivers door is from a 64 or later Corvette. Again the 63 used a one year part on the door trim. I have found this and replacing it. I removed the upper and lower A-arm and restored and repainted these...really didn't car for what I did before.
Got FOUR original 63 wheels and stripped them down, repaining and going to reinstall with BF Goodrich WW tires. Got an original 63 wheel for the spare, stripped that down, primed & repainted,,,SAE Gloss Black.
Replacing the parking lights, got the imports and they are wrong, go Trim Parts and they are better, but early 63's were a little different, but scarce to find the original.
Redoing the badging, especially the side, Early 63's through Feb used the same that was on the 62...so I need that.
Got a NEW gass tank and replacing all of the gas tank area, all new hardware.
Finally doing the grease pencil and stencil markings on body...
Oh yeah did I mention I will be replacing the two rear glass windows with new ones date coded to the ones on the car.
Replacing the two female latches, the hood support, and the battery....
All this has to be completed by May.... so we are off....
