V
vettekingz06
Hi to all---A month ago i needed help with these codes on my 2003 Z06 and got some responce. I have found my problem to be a broken exhaust valve spring on cyl 2. By luck it didn't drop the valve down in the cyl. and it looks as though i will be able to repair it with a new spring. The car only has 7000 miles and has not been driven hard. When we looked at the misfires (code 0300) cyl. 2 had the most misfires ( 120), with other cyl.s ( 3 and 8) having 4 or 5. It was making a very slight ticking sound but not enough to suspect a broken spring. I thought i had a vacuum leak and looked for that to no avail and then started to look at the random misfires. I hope this will help someone find this allusive trouble.
