Maybe this sounds familiar to some here? Have a 1982 - Was trying to get at vent ductwork to fix a problem. Took gauge & shifter bezels off and was able to get at blk plastic ductwork for AC / def / htr, etc... Verified the cold/hot lever opened & closed that vac actuated metal 'door' in what I'd call the heat exchanger(?). Did just a general check of the vents, etc.. is all.
Anyway I believe I have SOMETHING bad going on now w/vacuum. Simply disassembling then reassembling these things in the interior, under dash, has now caused the car to: 1) It now barely idles, more like surges then almost stalls over and over. 2) The headlights never did come up, but now the driver side came up slowly. Just over all general erratic behavior. One good thing is maybe that tells me my headlight actuator is good(?) Haha. Will look next at vac can that JBP6000 mentioned on outside in pass fender, behind the inner one near kick panel. WILL report progress. :ugh
UPDATE - (a little lenthy but necessary) First, Thanks to ALL here that replied to my issues. I learned much by taking things apart under dash... (took gauge & console bezels out [1982] to look at vent/ductwork cuz had hot air in cabin.) Now my apologies. I can now see how leaving out one seemingly minor thing can potentially change an outcome. Meaning, I said "Simply disassembling then reassembling these things in the interior, under dash, has now caused the car to:..." That was incorrect. When I started the car after checking under dash to find it now rough idled, I had NOT reconnected the gauges. As mentioned in the thread, I tried disconn the vacuum hose at manifold so as just to be able to drive it, but found it still had the rough idle. So I just decided to put the interior all back together then deal with it later.
Well.. apparently, just reconnecting the large electrical conn to the gauges, with what, 8 prongs per side, (and also the oil pressure 3 prong conn.), made the idle go back to smooth, as it was before I started the whole project. So correct me if wrong but I gather the vac system hoses, actuators, plenums, etc... can all be checked but the electrical must be there too via the gauges being connected. Again my APOLOGIES, for if I mentioned I had NOT installed the gauges again before trying, some here may have said, 'hey, you DO need to have the gauges connected too by the way. hahaha. Future postings, I will detail [exactly] what I did. I still have vac issues that I should be able to get through ok, but idle is great now and can drive it! Best regards, New Vetter
