upgrade seats on a 76
  • Thread starter Thread starter rcrock
R
rcrock
I've been considering replacing my '76 seats with c-4 or c-5 seats for better comfort,etc. Has anyone done this modification? If so,degree of difficulty,fit,amount of modification required,etc. Thanks.
Ever consider the 79-82 seats?
Just really wanted to say howdy and Welcome to the :CAC
Brian :w
The 79-82 used seats are starting to get a bit pricey lately--however, they're comfortable and weigh 40lbs less than the 75-77 (and non PC '78) seats. They also hold up better than C4 and C5 seats over time. Easy install too. I'll find a pair one day...
Brian, are the '79-'82 a direct bolt in? I know they are a high back,what I'm looking for.Do the have adjustable backs....I'm 6'5",so a little tilt would help the headroom.Rick
6 feet, 5 inches :eek
You need a firewall modification :L
I tell all of my 'taller' friends... don't buy a C3 unless it's a vert!
I can't answer your question about the rest Rick, but I'm sure someone else on this forum has done this and will chime in soon.
Later... Brian
iput 82 seats in my 75 . the front bolts are a line up , but you must redrill the rear ones and put a nut and bolt thru them . they are lower on one side so you will have to shim one side. this conversion will add 1 inch to the seat height and i would not do this to a non tilt wheel. i paid 600 dollars for my seats.
I have a set of 81 seats in my 76 and they bolted right in. I bought the car from a friend of mine who originally put them in. I'm not sure if he changed out the sliders from the 76 seats, but I have a call into him to ask. It didn't look like there had been any modification to the seat frames or the floorboards on mine.
Good Feedback! However,if They Set One Inch Higher,i Don't Have Enough Headroom To Give Up An Inch. Thanks To All.
my buddy is 6 feet and can stretch a little and look out thru the t top. i'm 5-10 and feel like i'm sitting on a pillow.mike
I'm 6'2" and I fit in mine just fine with the 81 seats. I also have glass t-tops which helps. My cousin's 80 has regular t-tops and my head doesn't hit them. He is the same height as me and he says he doesn't have a problem either.
