Upper Door Trim Panel, R&R
  • Thread starter Thread starter CharlesBrown
C
CharlesBrown
Need to replace the upper door trim panel on my ’88. I have the replacement part which appears to be a “:push-on.” Having said that…is this a job where all I need do is pry off the old part and push on the replacement, or do I need to remove the door panel. From what I’ve heard all the C4’s are the same with regard to this panel so if you’ve done this job or are familiar with what’s needed…sure like to hear from you
