J
jorge33265
I just had my oil pressure switch changed this weekend as well as my climate controll head. So this is a two part question. The car seems to be running fine but I hear what sounds like a vacume leak comeing from the intake manifold area. I removed the covers and all the lines seem to be ok but its kinda loud. You can here it with the hood closed. Sounds like a vacume leak.. I got a check engine light but when I checked the PCM it said its b/c I removed the horn relay. Thats a whole seperate post though. The second part to this question is after the climate controll head was changed the ac is blowing threw the front windshield and some out through the front vents.. On the head I can change the mode and it changes ok but the air doesnt blow to the feet or the windows ect. Is that vacume driven? Anyways thanks in advance for your help.
