Help! Vacuum line to HVAC controller in '86
86-ZZ3
Vancouver BC
'86 HT
I'm trying to debug the multiple problems in my '86 with the C68(?) electronic HVAC control. Looking at the vacuum outlets from the top of the runner, I only see one vacuum hose to the fuel reg and the other to the check valve which goes to the cruise control and the fuel recovery canister(?) I cannot find the vacuum hose that goes to the HVAC controller. Can someone point me to where this comes through the firewall? (no FSM so thanks in advance).
At the check valve ,the rear line should run to the HVAC; the side line goes to the fuel evap canister teeing off to the cruise control on the way .
The HVAC line is part of the wiring harness on the firewall behind dist ; black plastic tube only sticks out about 2" from wiring.
Thanks. :thumb Is the harness that biggest one has a bunch of wires coming out of the firewall just behind the right side valve cover? I see a thick vacuum hose but no outlet. Must have popped back into the harness somewhere along the way.
I'll remove the distributor/cap today and see if I can get it out.
