Valve Cover refinishing...again!
C4ME
Huntsville, AL
1986 Z51 (Al heads), Auto
I know this is a "whipped to death" topic, but I ran into a situation that I am looking for info on.
I had my covers bead blasted and the result is...wow. There seems to be a lot of defects in the covers that look like casting issues. Has anyone found this to be the case? I am not sure how to fill the defects that will not be covered by simply repainting. Some are actually raised blemishes, so I know that the folks who cleaned them did not cause the defects.
I was thinking that I could fill them with some kind of high temp filler and grind down the raise stuff.
Any suggestions?
P.S. Has anyone heard of any company doing reproduction valve cover emblems?
Yes. I painted them anyway and the result was less than specacular, but they look lots better.
:w
They're made of porous magnesium, hence the rough cast look, as well as being the reason for the discoloration that will reoccur every few years; oil seeps through and discolors them, then you have to refinish 'em again. ;)
Does anyone have an opinion on using JB weld like bondo and filling some of the defects that paint won't? It has good high temp properties and that is what I would worry. I imagine as the covers begin to stain again there will be funny spots all over but considering where I started it will look good.
Hey if anyone wants to give away a valve cover emblem, just let me know!! (Notice the operative word GIVE, we can consider it a tax deduction as a charitable give!)
Joe
P.S. I also had my plenum, tudes, and manifold blasted. Any suggestions on finishing these before reinstall? I was considering a good cleaning with a mild solvent and then perhaps a coat of high temp clear on the tudes and plenum to keep the staining to a minimum.
Joe
