brumbach
Once the valve spring is removed, how do you remove the valve from the head? Seems like I should just be able to pull it right out but it'll won't go all of the way. What's holding it? Thanks -- Bill
Worked like a charm. Thanks -- Bill67l36driver said:Valve stem tip is mushroomed by the wear from the rocker arm. File the edge with a 6" mill bastardand it will fall out.
