Vette/Berlina-coupe
- Joined
- Nov 18, 2002
- Messages
- 284
- Location
- southern california
- Corvette
- C3-coupe/MercedesBenz-540K replica! Racing-SB-V8!
FOR SAFETY SAKE: -perhaps someone with the capability could experiment with drilling hundreds of say 1/4"Radial-holes (try initially on obliquely-staggered 1/2"-centers) in the brake-drum's surface (doing same into the brake-shoes is not the same), in order to thereby effectively increase the binding-friction of the brake-shoes! One would naturally preferably use two C3-Vettes of same weight and identical brake-shoes for comparison, -thus first testing both for braking comparison prior to the perforation-modification at different speeds(shooting video to document the results before/after)! This notion would be somewhat akin to the racers now popular practice of cross-drilling the disk-brake Rotors, as to attain greater friction and enhanced cooling-ventilation. -If it significantly improves performance as seemingly predictable (without drum bell-mouthing), one could indeed have a thriving/nitch-market radially-drilling these inadequate C3/Emergency-brake drums to actually slide one's rear-tires(or even hold on a hill pray tell), particularly useful in emergency situations when the Hydraulic-disks have taken leave (as has happened to many of us without warning). A viable alternative to radial-drilling would be to instead apply a very coarse Metal-spray to the iron-drum's internal-surface, -aluminum-oxide for example having a hardness quotient of 9 (based upon a scale of diamond being 10), maybe giving it a 48-grit/sandpaper like consistancy; --definitely requiring use of tougher Kevlar/brake-shoes. It was irresponsible of GM to have sold a performance car with such a defective emergency-brake; --anybody up for such a worthy enterprising experiment (people as reflected below are complacent, -only getting serious about safety after someone has become tragically maimed, ---so probably nobody will persue this proposal) to surely save some lives, --maybe that of a loved one! (your beloved C3?)... ~Bob VonHeck
;help
Commentary: -the neg.-replys below are not accurate, but Joe makes an excellent suggestion as to scientifically evaluating vital ongoing modification changes on a Brake/Testing-machine (albeit that real-world seat-of-the-pants results nevertheless still being the ultimate test); --however, his expressed skepticism appears erroneous owing he fails to take into account that insufficient brake-drum sweep-area is the very problem! So my "Hyper-friction E-brake"-principle serves to make the existing drum-area much more effective via the "intrusion-effect" of the brake-shoe composition material momentarily actually minutely receeding into the myriad perforations, which resultantly greatly increased-drag is what the skeptic-critiques are failing to comprehend! Special relatively soft Kevlar/brake-shoes would be my recomendation, it can take tremendous abuse, would exhibit desired perforation-intrusion, -but does not have ability to withstand prolonged-heat (as it is still an amerid-fiber derivative of plastic-resin), -but heat-generation is not a major factor in a panic-stop situation, -when you yank on your Emergency-brake at 60mph, or are parked on a steep-driveway for example... ~B.vH
