leeboy66
I'm purchasing a VBP Monospring kit and I'm not sure what the difference is between the polyurethane or rubber cushions. The price is the same, but you can order it both ways. Why should I choose one over the other?
I'm purchasing a VBP Monospring kit and I'm not sure what the difference is between the polyurethane or rubber cushions. The price is the same, but you can order it both ways. Why should I choose one over the other?![]()
Poly is the way to go. While you are at it- order the longer spring bolts so you can dial-in the height the way you want it.
