J
jtburkh
Recently I took my 92 to the dealer to get the heater core replaced...
While it was there they told me the rear wheel bearings were looking worn beyind "normal" and they wanted to replace them. I declined since I could do it myself.
A couple of days later while driving home from work and on the highway I noticed that when I accelerated I could feel the rear end pulling funny. It felt like the rear was going out to the right. I know I wasn't spinning tires.
When I got home I looked underneath the car and noticed that on the inside of the left rear tire there was a faint wear on the tire where it had rubbed up against the exhaust muffler. The rear tires are 315's and have a close clearance to the exhaust but this has never been a problem.
So, I figured the wheel bearings had finally bought the farm and I replaced them easily enough following the directions, to the letter and some, from a chilton's and hayes' shop books. I can still feel the problem when I accelerate though so now I'm wondering if the shocks, transverse spring or bushings are bad or if I just need to get an alignment done. I have some experience working on C3's, and the rear wheel hub and bearing replacement but I'm ignorant of what could be causing this.
Also, I've been googling all over for some place that gives good decriptions of problems. Chilton's and Hayes just tell you how to take apart and install stuff but I'm not seeing anything good that would tell me why I need to do something or help me troubleshoot a problem...so any tips on a good tech manual would be great help.
Thanks in advance for any insight.
John
John
