rlg
Hello from Okla.
I have had many Vettes over the years most of the 63-79. And have done several restorations.
This is my second C4.
Here is what happened.
The previous owner cut the pre cats off, bad job.
I replaced the entire system, removed all cats. I also removed the guts to the air pump. as we were finishing up my son pushed the Air tube against the starter, when I hooked up the battery it smoked pretty bad.Moved the tube ,the car started ok. The next weekend I supported the tube out of the way.
Started the car drove it for about 15 minutes then it started to idle badly.
Now it will crank ,start but won't idle on it's own. I can keep the car running at 1000rpm or more but when I let off of the pedal it dies.
Replaced the ecm unit.
Still does it
The radio also stopped working and the oil pressure gauge jumps around when you turn on the key.
No check engine light , All fuses ok.
I have all of the manuals but don't see this problem.
I read a post here this morning that talked about the 8th injector.
Recently tuned up And ran well (little miss at idle) before I changed the exhaust.
I know how to retrieve the codes but was wondering if anybody knew the short version of what happened.
Any ideas??
Bob
Still does it
Any ideas??
Bob
