- Joined
- Aug 29, 2001
- Messages
- 3,239
- Location
- Norcross, Georgia, United Stat
- Corvette
- 2017 Arctic White Grand Sport
I am getting close to getting my a/c working perfectly. The thing blows at 38 degree while moving and once I get the heat from the floorboards insulated, I should be in good shape.
The problem I am having is that at idle and as the RPM's come down from revving the engine, there is a noticeable shake in the a/c belt. It can actually hit a metal tab below the belt and scare the s**t out of you if you don't know what it is. If you accelerate, the vibration goes away.
It has a new R-134 compressor. We checked with GM today and it is the correct part. The belt has been changed out twice.
77-4Speed had what appears to be the same problem, http://corvetteactioncenter.com/forums/showthread.php?s=&threadid=12581&highlight=compressor, though I can't tell whether or not he ever resolved it.
The a/c shop seems to think that I need to replace the plastic washers and spacers on the mounting bolts as there is the possibility that they have worn and are allowing the vibration.
Anybody else have any other ideas or any ideas on where I can get these things or the descriptions so that I can attempt to locate them. I have the GM part numbers, 120394, 492346 3880353 and 3820389.
Bob
Bob
