M
miami993c297
VIDEO + SOUND : idle, revs inboard, music from the outside, cruise in 6th of my Z06 after mods & tune
that was just after the dyno session, since there the engine has break-in and the rev limiter is now set at 7200rpm, the car became just faster everywhere :
The first clip is idle @ 850rpm:
http://s27.yousendit.com/d.aspx?id=214BZBC59D5Z32B96KOSM5DATQ
This one is Revs Inboard :
http://s28.yousendit.com/d.aspx?id=01ZA31Q2LGOW8164L93XDSMFB2http://s7.yousendit.com/d.aspx?id=0FILW0TGU5ZOJ1Q8TM37H1UVFA
Now it's Music from the outside (longer) :
http://s6.yousendit.com/d.aspx?id=0OA8VJ0JB3H6V12NH7726DIM1A
you finish with Cruise in 6th @ 1100rpm :
http://s2.yousendit.com/d.aspx?id=31UJLPQ2MWO1R13YE9IKHIBJGV
When you are on the link you can right click and save
Have fun
Christian
this is the list of the mods:
Kooks 1 3/4" x 3" with Weld-On Collectors, Stainless Steel,
Kooks 3" x 3" Off-Road X-Pipe
SpringKit Precision Race Components Gold Spring Kit With
Titanium Retainers, Seats & Seals
Texas Speed & Performance Chromemoly 7.40" Pushrods
Rollmaster Double-Roller Non-Heat-Treated Timing Set for LS1
ASP Underdrive Crankshaft Pulley, 1997-03 LS1 Corvette
Donaldson Blackwing Induction Kit, 1997-2004 C5 & Z06
MSD 8.5mm Spark Plug Wires
NGK TR55 Spark Plugs
COMP CAM Grid #LS1 3722R/3720R HR16
Valve timming :
Open INT: 2- BTDC , Close INT: 46 ABDC
Open EXH: 48 BBDC , Close EXH: 8- ATDC
these specs are for cam installed @ 114 ICL
224/220, .581/.581 @ 116 lsa
Have fun
Christian
Valve timming :
