S
Skant
I'm having trouble with noisy whiney 4.10 gears. The shop replaced them with Dana 4.10 gears, which were guaranteed to be quiet. They weren't. Their source is willing to take them back. They recommended putting in the Viper 4.10 gears. So the shop has tracked down where to purchase the Viper ones from, and now they're working on getting a Viper carrier.
They're describing to me that the Viper 4.10 gears are larger. So they don't make the noises, where the 4.10 ring and pinions I've had had noise issues because the ratio forces the pinion to be too small (or some part of it is too small or something).
Okay... this all makes sense to me. I've heard from a lot of sources that the 4.10's wouldn't have any issues if the car had a larger carrier.
But here's my confusion...
I'm doing research on the matter myself and finding listings that show that the Viper and the Corvette (C4 manual) actually use the same carrier... something called either the Dana 44 V or Super Dana 44.
I've found posts here that talk about using the Viper gears and indicate that they'll work in the vette's carrier, but a little bit of the carrier has to be ground away to make clearance.
So what's the deal here? Are they different or not?
Originally, I thought the Dana 4.10's I was having installed to replace the noisy gears _were_ the same ones as the Viper. At least, I assumed that because they were Dana gears. But now I'm told this is not the case. The Viper ones are bigger.
Can anyone clear this up? Does the Viper have a different carrier or not? Are the Viper 4.10 ring and pinion different than the Data 4.10 ring and pinion for the C4 manual tranny Corvette? If the viper gears are larger, are they larger enough to not whine in 4.10?
Thanks in advance!
- Skant
Thanks in advance!
- Skant
