Washer fluid resevior replacement
williamm_c3
Big Sandy, TX
1981 Black
Has anyone had to replace the washer fuild resevior? Mine has a hole at the bottom and wanted to replace it; however, I don't see how to get the old one out due to limited space. Are replacements smaller?
Thanks,
William
Hi Bill, I would like to know how to do that. Mine leaks and is missing the remote fill tube. It looks like it might be more trouble than its worth. Anyone here done this before?
Thanks,
Gary
I just ordered a new washer assembly, so I'll be installing it when it gets here. However, I have already pulled the old one out. What you have to do is get at it through the bottom by pulling the left splash panel off. Then the vapor cannister has to come out. It wasn't that bad really.
Thanks Photovette! I'll give that a try. It sucks not having fluid down here with all the residue coming off the streets right after a slight rain.
