I agree with Red
Your front window seal may need replacing, but that could be just the start of the problem. Front window leaks usually mean rust.
My advice would be to get a window fella around and remove the front window, clean the frame up and reinstall it. Only drama is that when you pull the window out, the frame could be rusty and that's when you have problems. Is the water leak a small leak or does it have a small lake in the footwell?
If it is a small leak, then just the Urethane seal needs replacement and this is not really any great problem. Removing the whole window gets a bit difficult around the bottom corners (cutting the seal with wire and not the dash).
You just gotta remember that the seal is old and they will shrink and crack letting water past. If the leak is a lot, then you have cowl leaks and this could mean getting out the welder and removing the dash.
Check the wiper well for holes as well.
I had a series of leaks, but the window and rear windows reseals solved a fair bit of the problem. I have only a small amount of water coming past the side windows, but I am going to re-hang the doors with new bushes, before adjusting the window.
Good luck with it, hope it is not the cowl leak!
Cheers
Tony
