Water Temp Gauge Not Working (69)
  • Thread starter Thread starter ernie d
E
ernie d
Hi everyone,
temp gauge was working fine, had to pull out center instruments stack (for a different reason), put it back together and gauge doesn't work now. It is a 3 blade connector. However, there was another lead that comes from a condenser that I must have put back on the wrong one of three gauge terminals.
Anyone know which terminal the condenser lead goes to?
ernie d said:
Hi everyone,
Is the wire (green I think) on the left side of the block (at least on the SB's) connected to the switch? Mine easily disconnects when I'm working in the motor compartment near it.
water temp gauge
I'm new here and this is probably an old thread but did you ever find out were that wire connects too? I have the same problem
