C
caredvette
I just installed the c5 column lock bypass, it went in without a hitch. Today after driving for about 15 minutes the dashboard died, all needles dropped to zero, and the display showed all ************************. I disconnected the battery and then reconnected it. Drove fine for about 15 minutes then the fuel gauge dropped to E, and low fuel displayed on the IP. I also got the dreaded pull key wait 15 seconds message. No significant codes were stored. I called Corvettes of Houston and they insist that the bypass is not the source of the problem, I have disconnected the bypass and all seems fine, but I have not driven the car for any extended period of time. Any input would appreciated
