BVFD25
So I have a 1994 non zr1 it has no performance parts and is all stock. My problem is that I have had a rough low idle for a year or so now, runs about 500 or so rpms at idle in gear, you can see the dash lights dim back and forth with the idle and can feel the car shake a little like a lifted cam. I have replaced plugs, wires, distributor, map sensor, egr valve. I had it at the dealer for three days, they did an induction cleaning on it, and a compression test, and then gave up. Now the big problem. I don't drive the car to much long distance, but in September I had to drive about a 6 or so hour trip, that's one way. Car did great going down, but when I was leaving the hotel to go home the car shut off in the parking lot, just like I turned the key, no stumble, or sputter. But it started right back up, and I headed down the highway. About 5 miles from the hotel, while doing about 75 mph on the highway it shut off again, same way, no warning, I left it in gear (drive, it's an automatic) and I shot across three lanes to get to the shoulder, before I get there the car springs back to life on its own and takes off down the road like nothing happened. Everyone I tell this to has never heard of a car doing that. It did this two more times, with about 5 to 10 miles between. So I stopped and filled up the tank which was about half a tank, thinking I got some bad gas. After that no more problems the rest of the trip which was still at least 4 hours. About a month or so later this has returned, it randomly shuts off like you turned the key, if the car is moving it will restart on its own, but sometimes it will do it like sitting in bumper to bumper traffic, or when you go to pull out of a parking spot. When it shuts off, the rpm gauge goes to zero, but everything else is normal just like if you get in and turn the key, other gauges still read normal, but the battery light comes on, weirdly enough the engine light does not, the radio stays on, and lights stay on. And it Has never given a code. I really need some help, cause I drive this car pretty much everyday.
