green 84
Just replaced the mufflers on my 84 which were clamped on and got to thinking that the CAT was most likely the original. Figured I wold unbolt and change it out for a hi-flo which sounded easy enough. Took a quick look and it appears it is welded on.....The best I can tell is that the 2 bolts on the top/verical ends are holding the heat shields on. Is welded the norm from the factory? :W
Thanks for your time.
