Wella.......Wella.......Wella..........
A
awesome 72
Got my 350 on a stand, but can't decide which way to g.
I want the simplest way to raise the hp. Should I turn the
crank and put in tutonich flat tops, Get a 383 pre-balanced
kit. Buy a new crank, Supercharger. Any suggestions welcome, TY. Also
What supplier choice can is there :)besides Summit.
Mark.
Evolution1980
Administrator
Cleveland, Ohio
ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
There's two questions that always get asked right off the bat. They are the most important questions.
1) How fast do you want to go?
2) How much money do you have?
What is the condition of the block that using?
minifridge1138
USA
1982 Black Fastback
Those are the 2 questions to ask. Although the answer to #2 determines the answer to #1.
Good Luck!!!
The73vetteman
Michigan
'73 L48 4spd
Hey Mark, I see you didn't get many replies, so let me lob a few thoughts across the pond at ya.
1. If it's the original numbers matching motor and resale value is a concern, then don't mess with it. If you want serious hp buy a crate motor and put the 350 in storage.
2. If you want a mild hp increase, I suggest you look at the breathing - headers, new manifold, new carb. After that, look at the cam.
3. There are loads of vendors out there on the net. Summit are good, but look at Jegs too.
4. If you want a more detailed response, give us some details of what you've already done and how much you want to spend.
J
Curby
Alabaster, AL
71, 72, 73, 82, & 00
$1,000 to $2,500 budget = cam, intake, headers, carb
$3,000 to $4,000 budget = above with heads
$5,000 to $7,500 budget = above with 383 stroker kit
$8,000 to $10,000 budget = supercharger
$15,000 budget = 572 crate engine
Evolution1980
Administrator
Cleveland, Ohio
MMMmmm...If he's doing the labor himself, he should be able to fit in a nice pair of heads into the price range of the first group. He can get some top notch AFR heads (180cc Ported/polished) for about $1500. The other components you mentioned shouldn't cost him $1000.
But otherwise that's a pretty fair breakdown you gave. :upthumbs
Here's a good article on the AFR heads I mentioned versus the equivalent GM Bowtie heads...
A
awesome 72
TY Guys
Thanks everyone.......keep em comin....I'm areadin
Mark.
A
awesome 72
Uhhhh ???????
How do you blueprint the:) orig. engine.
Koop
Kalifornia
YELLOW 69 modified GM Crate ZZ383, LS2 TBSS
Put L48 on garage floor, spray blue around it, then buy a ZZ4.
Evolution1980
Administrator
Cleveland, Ohio
Koop
Kalifornia
For you smog control guys.
I was at the local Corvette shop and got to see their latest creation. They stuck a HT383 in (looked like a 1981) a newer car. He says the computer, carb and ignition works perfectly with it and it passes California Smog! Sounds like a great solution to gain HP and still pass Smog for that car.
I didn't get to go for a ride in it, yet. :)
A
awesome 72
Well we got it almost ready, just waiting for bearings tool and gonna have a crack at that, then rebuild rain or shine with flat tops, new rings and voodo cam.
Whatdya think.good choice, will taht work. My email is hypemarketing#yahoo.com please keep in touch. always nice to hear from Brother Vetters. Into her around $5000 so far
South Dakota
76 Coupe
What is the voodoo cam ? Is that the one that launches the lifters off the cam just before peak cam lift ? If it is I would avoid it. If your cam is much better than stock (ie. bigger duration and lift) you may need an aftermarket intake and better than stock heads to take full advantage of it. If all the parts are not matched for the performance they should each deliver, then you will have a dog and be kickin yourself till you change it.
