What about speed bleeders?
A
Alfonso Gomez
I'm about to install speed bleeders in my 87 Coupe. I have heard good things about them and also bad things. One comment i have heard is that the leak. Anybody has them? Any problems with these bleeders? I will appreciate any comments (good or bad) about them.
Mustang, OK
'13 427 60th vert - '21 Silver Flare Coupe - CTS V Wagon(4-door Vette)
I had "Speed Bleeders" on my old '92 Vette for years and never had any problem with them. Came in handy when time to bleed the brakes and change out the fluid after a hard day at the track.
1
1stiff84
Speedbleeders in our C5 have performed well for us.
c4cruiser
Lacey, WA USA
87 Gold Z52 Coupe 02 EB Z51 Supercharged Coupe
Are you getting the Speed Bleeders (from the company by the same name) or the Russell versions?? I have heard a lot of stories about the Russell versions havng leakage problems.
I have a set of Speed Bleeders on my 87 and so far, I have had no problems at all. Speed Bleeder sells a small bottle of sealer that you can use to replace the original sealant. After a dozen or so cycles of loosening and re-tightening, the sealer will begin to come off and it needs to be re-applied to insure an effective seal.
Just make sure the the threads in the calipers are in good shape. Follow the instruction carefully for the initial installation and you will be OK.
When I bought my Speed Bleeders, I got the bleeding kit (a 3' length of tubing and a plastic bag to hold the old fluid) and it was well worth the 6 or so dollars. The sealant was about $10 so I got it at the same time. I do a lot of autocross and some track days so I frequently bleed the brakes. The Speed Bleeders make it easy to do by myself.
