Question: What Adhesive to use?
Dayton, Ohio USA
'74 383 4 spd coupe
Hey guys, while I had the body off the frame, the front fender on the passenger side started to pull away from the main body just under the windshield frame. Any suggestions on how to secure it. Should I do it before or after setting the body?
Sheet Molded Compound. The type of fiberglass used to make Corvette panels after 72-73. The older (68-72) polyester resins used in the earlier panels will not stick to SMC and vice versa.
If the panels on your '74 are original, they are SMC.
I believe it was started on 73 Models
I use Fusor 127EZ,Strong Stuff!!:thumb:thumb:thumb
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
