What do these numbers mean?
  • Thread starter Thread starter MagikDraggin
M
MagikDraggin
I see a person mention that their cam is (for example) 224 581 with an lsa of 114+2.
I know what all the other numbers mean, but what's the +2 all about?
The +2 indicates that there are two degrees of ground-in advance.
You can find answers to just about any cam question over at ls1tech.com.
Ground-advance? That means something like early opening?
Yes, subtract the intake lobe centerline from the LSA to determine ground-in advance. The net result is to open the intake valves sooner, with the side effect of also decreasing piston to intake valve clearance.
HTH! :beer
