What do they do? How do they increase performance? Can I install them on a stock LT-1? What kind of tools are needed to get this done? How complicated is the install? What can break if the install is not done correctly?
Thanks!
Thanks!
Roller Rocker Arms replace the stamped steel OE rocker arms with ones that operate with less friction. Friction is a load that reduces horsepower … less friction equates to more power … rolling cylinder / bearing reduce friction. OE stamped have no bearings … they have a simple (but very reliable) fulcrum ball at the rocking point and they simply slide across valve tip (also very reliable). Some aftermarket “stamped roller tips” are also stamped steel and utilize the OE type fulcrum ball but also employ a rolling cylinder that rolls across valve tip. So called “full roller rockers” are typically aluminum extrusions and have a needle bearing fulcrum at the rocking point in addition to the rolling cylinder for valve contact.tonyk72 said:What do they do? How do they increase performance? Can I install them on a stock LT-1? What kind of tools are needed to get this done? How complicated is the install? What can break if the install is not done correctly? Thanks!
Two more important questions to ask:tonyk72 said:What do they do? How do they increase performance? Can I install them on a stock LT-1? What kind of tools are needed to get this done? How complicated is the install? What can break if the install is not done correctly?
Thanks!
Some claim as much as 15% increase in HP ... I dunno about all that. Cost from about $150 to about $400 a set to fit studs as in sbc vette. Yes, there are claims of lotsa production tolerance variation of RAR in OE stamped ... I've little doubt that variation exists ... but I dunno about how much ... or how noticable that much variation is to someone driving a 250-400 hp street car. Also, I've little doubt there's variation in aftermarket/roller rockers too ... again I dunno how much or if it really matters so much.Vettehead Mikey said:Two more important questions to ask:
How much more usable power will they give me?
What is the cost to aquire this usable power?
15% increase? So if I'm running a 375 horse motor, I can add 56 hp with these rockers? I wonder why all the combined intelligence of the GM engineering division didn't also know this, and install them from the factory. I protest! Class action suit! John H., where are you, I want an explanation. This is an insult! :L :L :LJack said:Some claim as much as 15% increase in HP ... I dunno about all that.
I will add this ... I've worked on several aircraft motors ... some WWII era ... in all I've seen (maybe 10 in all) the inards of em had full roller rockers from factory.
I think building another motor is the way to go.tonyk72 said:But the more I think about it, I think I'll leave my stock engine alone and start shopping around for a block to build up from scratch...I'm itching to do some mods & this might be the best way to go. I could preserve the original engine and do whatever I want to my "spare" engine...
Gerry, I understand where you're coming from - I don't have a dislike for vendors per se, just the way their marketing hype raises unrealistic expectations when they try to peddle "race parts" to people with ordinary street engines with ridiculous claims about the results. Many marketing types make their living simply lying to anyone who'll listen, and it'd take the FTC a million years to nail them all. A properly-developed engine is engineered as a "system" to serve a specific purpose, not a collection of catalog parts that "look good" in a 4-color brochure.GerryLP said:John and Drags, I sense on your part and maybe others a dislike of vendors, and believe me, I understand very well your sentiments, and I could be misreading you all, but its almost as if you won't recognize that there were many times that high performance vendors drove the production decisions at the big corporations like GM and Ford. Sorry, I'll get off my soap box now...or was it shot-off????
CAF ... NO ... the warbirds I've worked on are in private hands in south carolina ... same goes for working cropduster (steerman w/ pratt) ... for example:GerryLP said:Jack,
Are the restoration projects in which you are helping Confederate Air Force projects? The only project with which I have been involved is the restoration of an OH-13E Helicopter. This is an USAF version of the Bell-47 similar to the one shown in the opening credits of the M.A.S.H TV show. However, the restoration was only at a museum-level type of restoration. I was not allowed to restore it to flying status. Nevertheles, I had the oportunity to teardown the 6 Cyl. Horizontally Opposed Franklin engine and the entire airframe to its main sections including the removal of the cabin. What remains is to suspend it from its display location cealing. Historically speaking, its accurate.
