Vref
What is the best place to buy a bead blaster? and what brand name would you recommend?
http://www.tptools.com/prod_list_display.asp?dept%5Fid=L1%7E53&dept%5Fname%5Fp=Abrasive+Blasting+Cabinets&mscssid=FF9F01DVKD5K9GHML4SP5XW7FK7G0WT5ChuckG said:TIP in Ohio. Chuck
Based on my experience, you'll have problems doing a fan shroud or radiator support in that one. You may be able to physically get it into the cabinet, but you'll have no room to work, got to be able to get the nozzle back away from and to get around the piece you're working on. Also, should be able to turn the piece your're working on. That one will be hard pressed to conveniently do anything much larger than an item about a foot to 18 inches square, in my opinion.Vref said:I want to do a fan shroud, radiator support, fan, bolts, and whatever else I can get into it?
Thinking about this one; but I just don't know.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2497284863&category=43986
I am looking for all the pitfalls and advice on the buying one of these puppies. I got the size thing, Do they put out alot of dust, or are they clean? What is the vacuum attachment for? Why are the $800 ones better than the $250 ones.
I've got a 5.5hp 30 gallon compressor I think that should be sufficent.
