I have a 67 327/300 sb with air and a 1100750 62 amp alternator that is stock for this application. I am trying to find out if the 1119515 voltage regulator is the correct application for the 62 amp system. I wanted to upgrade to an electronic vr, specifically the wells vr715, but in the description from autozone it says "all except 62amp" sort of confusing as I do not know if GM used a different vr for the 62 amp alternator in 1967. Anyone have an answer or an application that works? thank you in advance for the great advice given in this forum, vinny
